pmeyers
I currently have an off grid water pump system that works well. Grundfos 6SQF-2 Helical Rotor pump, and Grundfos SQFlex controller and system monitor. Getting approx 5 gallons/ minute at peak. Right now, I have to manually turn the pump on and turn it off. I need a means to control the pump when I am not at the property to make sure that my tank doesn't go dry or that I don't over flow the tank. The obvious answer is a float switch, which I have and could connect to the controller, but the distance to the tank is too far to trench for the line in a very rock soil and if I laid it above ground it would be eaten by rabbits. It was suggested to me that I could put in a timer relay that would give me the option of having the pump come on a fixed amount of time each day. I wonder if someone has done doing similar and could point me in the right direction for a wiring diagram and parts list? The pump is powered directly from the solar panels through the controller and is rated for 5-240 vdc. Any advice would be appreciated
