Hey Gang,
I'm taking on a project to add a new basement unit in my sisters house (Edmonds, WA) and want to pass inspection.
The home has the old copper waste lines and vents. They are paper thin and already leaking from the soil stack.
The plan is to add WC, Lav, shower, Washer combo and Island sink. The original bathroom has a washer, WC and lav. Upstairs has a full bath. Basically want to make this a mother in law apartment in the basement.
Here's the layout:
When I removed the wall and concrete in proposed new bathroom, its all 1960's copper and super shallow.
It also has a heel coming from the 3 in. 90. I'm guessing this drains the lav on the other side of the wall but it was probably originally a clothes washer drain. That first Wye is draining the toilet on the opposing wall. The copper looks in bad shape.
On the other side of the foundation (exit house) the copper is going to a fernco 4 in. cement pipe to 3 in. but its left is plastic capped (left of image).
So here's are two plans. One is a lot of replumb work (old toilet flange, washer) and one is just adding a line for the new fixtures.
Both plans involve moving 4 in ABS inside the house and moving cleanout outside.
1. Remove Cement Wye and cut hub on sewer line
2. Attach new "metal shielded" mission style 4 in cement pipe x 4 in ABS
3. While still outside add 4 in. ABS DWV Hub x Hub x Hub Cleanout Tee
4. Install 4 in Wye (split to wet vent WC from shower, lav - add 2" drop for kitchen island and Studer vent)
5. Reduce 4 in to 3 in with Fernco to Copper to reconnect line
OR
1-4 is the same
4. Reduce 4 in 3 in
5. 3 in. x 3 in. x 2 in. ABS 90-Degree Hub x Hub x Hub Elbow with Low-Heel (low heel 2" to supply lavs, washers)
6. 3 in. ABS DWV Double Fixture Sanitary Tee (one to each WC)
7. Replace copper venting, dwv lines for lav, etc.
Any help is greatly appreciated!
Thank you!
Here's the layout:
OR
1-4 is the same
4. Reduce 4 in 3 in
Thank you!
