DetourDuck
I have a three-year old, 50 gal electric water heater, with a 3/4" brass ball valve replacement for the plastic OEM drain valve.
I would like advice on how to release the vacuum in the tank when I drain it for its yearly flush. I have seen two different lines of advice online. One line of advice is to open hot water faucets, the other is to open the tank pressure relief valve. I have done it both ways, with different results.
If I open the hot faucets to both the sink and tub in the bathroom adjacent to the heater--it takes about 8 hours to drain the tank. I either have to run the drain hose out the front door--there is not enough pressure to cause the water in the hose to go over the wall of the bathtub (my nearest drain), or I have to place a bucket under the drain valve, and empty the bucket every hour or so. If I open the pressure relief valve at the top of my tank, I can drain the tank in under 30 minutes, and I can run the hose into the bathtub. Obviously, I prefer the method of opening the TPR valve.
I recently had some plumbing work done to the cold water inlet to the water heater. The plumber asked if I flushed my heater regularly, to which I replied that I did. He then cautioned that one should NEVER use the TPR valve to drain the tank. I was told that opening and closing the valve causes damage to it, or that sediment could get trapped in it, so that it would need to be replaced. I'm guessing the sediment remark does not apply to top mounted TPR valves, but does simply opening and closing the TPR valve damage it?
And if opening the TPR does damage it, is there a way to get my water heater to drain faster? Do I need to be opening all the hot water faucets, not just one or two?
Thank you so much for your help!
