It is common for the 5600SXT to have a 0.5 gpm BLFC. Now your current settings seem to use a lot more salt than I would expect for 1.25 cubic ft of resin. Here is what I would think...
This is what I would use if things are working OK:
System info (not programmed)
salt lb/cuft = 8.4 ; A choice ( efficiency vs capacity)
BLFC = 0.5 ; Brine Refill rate GPM
cubic ft resin = 1.25 ; ft3 resin = (nominal grains)/32,000
Raw hardness = 22 ; including any compensation
People = 2 ; gallons affects reserve calc
Estimated gal/day = 120 ; 60 gal per person typical calc
Estimated days/regen = 11.36 ; Computed days ignoring reserve
Fleck 5600SXT Settings:
DF = Gal ; Units
VT = dF1b ; Downflw/Upflw, Single Backwash
CT = Fd ; Meter Delayed regen trigger
NT = 1 ; Number of tanks
C = 30.9 ; capacity in 1000 grains
H = 22 ; Hardness-- compensate if needed
RS = rc ; rc says use gallons vs percent
RC = 120 ; Reserve capacity gallons
DO = 28 ; Day Override (28 if no iron)
RT = 2:00 ; Regen time (default 2 AM)
BW = 5 ; Backwash (minutes)
Bd = 60 ; Brine draw minutes
RR = 5 ; Rapid Rinse minutes
BF = 7 ; Brine fill minutes
FM = usually t0.7 ; flow meter, make note of what is there
FM = P0.7 ; usually t0.7 but Paula has a paddlewheel;
When measuring your water hardness/softeness, test the hard water. The water heater hold a lot of water, so the hot can be slow to change.
Could be. Force a regeneration, and watch during the brine draw how long it takes for all of the brine to be drawn out, and in fact, make sure it is drawn out. The draw should be to about the middle of the air check valve. If you cannot see well enough, maybe use a yardstick as a dipstick down the brine well.Also, I just checked the water level in the brine tank and there is 21 1/2 inches of water with the last settings I used (relisted below) Is that part of the problem? Could it be a clogged injector or something like that?
DF = Gal ; Units
