DanMeredith
I just had a plumber replace the cartridge in my Moen bathtub single handle control unit. The next time I got in the shower and turn the control fully counterclockwise it does not go all the way cold but just less hot. Clockwise goes extreme hot. Counter clockwise goes less hot/warm but never gets to cold. it has been some time since I have worked on one of these but as I remember there might be an adjustment inside the handle without pulling the cartridge comma to adjust hot and cold limits. If I pull the plastic handle off is there an adjustment inside that will allow this to open more cold water when I rotate counterclockwise? I would like to avoid having to call the plumber back out again for something simple. Thank you
