Tejas
Hi,
I am a trying to finish my basement. During the process, I wanted to add a bar sink at a location. In order to plumb everything correctly, I needed advice.
The sink for the bar is about 12 - 13 feet from the nearest drain pipe which has been provided for a sink in a half bath. Half bath has a rough in for a toilet too and a three inch drain pipe close by. I have shown it labeled in the images. All images are below.
Here are my questions -
-Tj
- Can I connect the bar sink drain pipe to the 1.5 inch pipe provided for the sink in half bath?
- If yes, how would I go about connecting the two. I have two images showing a direct connection as option 1 and option 2 has a side branch to the 1.5 inch vertical pipe and then the bar sink drain attached to it. Which would be the best and correct way out of the two. If both are not right then please suggest an alternative.
- Do I need to have a vent line for the toilet too which I would have to connect to the 1.5 inch vertical pipe provided for sink in half bath? Is that needed and or allowed? If the toilet needs to be connected to the 1.5 inch pipe then are three connections allowed on the vertical pipe?
-Tj
