twainer
I purchased 3 fleck 5600sxt heads to replace the old rainsoft ones on my tanks at home. Two of the heads are setup as filters/backwash only, the 3rd is a softener with brine draw etc. I didn't realize the softener head didn't come with a flow meter and had to purchase that after the fact as an add-on.
My question is there any reason why I couldn't hook that fleck flow meter up to all three heads and switch them from timer mode to metered mode? I think I can use a digital IC to fan out the output pulses from the meter so I would have one for each unit. I'm just not sure changing the program for the filter heads will work out the way I want it to. My thought is to use the meter to trigger the backflushs for each tank and use the time setting to ensure they all took the right turns flushing so as not to interfere with each other.
This was always a problem with the rainsoft system--the timers would get off and they flushed randomly.
tks
tks
