Martin Jahn
I am working on adding a single basin utility sink in the garage, adjacent to an existing bathroom. The existing bathroom has a sink with a 2" drain line going to to the slab and a 1-1/2" vent line. The distance between the existing 2" vertical drain line and the outlet of the new utility sink is going to be just over 36". The top of the bathroom sink will be about 4" higher than the top of the utility sink.
Based on what I have read, I need to install a second sanitary tee below the existing one that the bathroom sink is using to feed over to the utility sink (due to the large structural post, the horizontal feed to the Utility Sink with run outside the wall but inside the bathroom sink cabinet).
Then also run a new vent line up from the sanitary tee at the utility sink and join the existing vent (in my case above the ceiling).
Does this sound/look correct?
Should I being using 2" for the drain line to the utility sink or can I use 1-1/2"?
Is there any dimensions I need to concerned about such as relative height between the two sanitary tees where each fixtures P Trap will connect?
Is there an easier way?
