Rugz31
Hello all. I'm going to attempt my first major plumbing project soon (other than replacing galv lines with PEX) and need some advice or input. I've been researching and reading as much as I can on here to avoid having to make another post like this, but some advice I was recently given has me rethinking everything.
I need to add another drain line for a double sink vanity, currently only have one drain and it's centered. I will need to move the drains to the left and right of where the drain currently sits. The current drain pipe is 1 1/2" so that will need to be changed to 2" to support a second lav. Current plumbing below.
This is the design I was planning to use, but someone told me I'm planning to do more work than I need to. Is this the correct way to plumb this, or is there an easier way that I'm not seeing? The other guy told me I should do something called a horizontal common vent, which would meet IPC code and involves less work.
This is a 1 story house with cement slab foundation in Houston, TX, if that makes any difference.
