I currently have a large beast of an American Standard oil-fired boiler that dates back to the 50s. In addition to heating the house, this thing does a decent job of providing domestic hot water for my 2400 sq ft, 3-bathroom house. The reason that I say decent is because we experience a fair bit of temperature fluctuation during showers and sometimes water will go cool for a number of minutes, which I assume is due to the boiler being used for heating. As you can imagine, the boiler costs a ton to run (and my basement utility room sits at about 82 degrees even in winter).
I'm looking to add a heat pump water heater to even out temperature fluctuations and decrease reliance on using oil to heat water. Until we replace the boiler, which isn't in the immediate budget, I assume the HPWH will benefit from using the heat put off in the utility room. I'm wondering if it's possible to plumb things so that hot water will be supplied in priority from the HPWH tank and then by the boiler coil if the tank runs out. The reason I think this would be helpful is because with a family of 4, I think we could mostly get by with a 50 gallon HPWH but we may need a little extra help when we have guests and as our kids get older.
I know that some have placed water heaters in series after the coil, but because I understand that a heat pump is generally going to be more efficient and cheaper than heating water in the boiler (especially my ancient one), I wouldn't think you'd want to do that with a HPWH. What I'm imagining would be like a valve setup that switches supply over to the coil if the tank needs to recover. Is a setup like this possible? If possible, would it be cost effective and sensible to do?
