Adding C to my Nest thermostat
Discussion in 'HVAC Heating & Cooling' started by Crewel, Jun 24, 2017.
  1. Crewel
    Crewel New Member
    Jun 24, 2017
    CONUS
    hi all,
    I currently only have 4 wires running to my nest. I see that my furnace supports what appears to me as a common wire. It is currently being used by the AC unit outside. One wire on "Com 24" and the other on "Y"
    My question is: can I add the unused blue wire from the thermostat wire (you see it wrapped round the outside) to the "Com 24" on the PCB? I am afraid to do this because the AC unit outside is already plugged into it. I wasnt sure if that would mess it up.
    Any thoughts?[​IMG]
  2. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
  4. Stuff
    Stuff Well-Known Member
    Mar 7, 2013
    Pennsylvania
    No problem. Done all the time. Look how there are two wires on Y.
  5. jadnashua
    A typical thermostat is just a fancy on/off switch...it only connects the hot lead to the one needed to either turn on the a/c unit, or the heating unit...the other side of the power (always takes in/out), is after the control in the device (the furnace or a/c unit). The Nest thermostat (and many other smart ones) work best if they can get external power...that takes both in/out. The common is the other half of all of the control lines. As long as the furnace's transformer is big enough to handle the load (and pretty much all of them are), it can power your thermostat.
  6. Crewel
    Crewel New Member
    Jun 24, 2017
    CONUS
    Thanks all. I tried it and it worked as expected. Nest now sees the C wire supplying 25VAC.
Similar Threads: Adding Nest
HVAC Heating & Cooling Adding a zone for my basement to a single zone house Sep 19, 2020
HVAC Heating & Cooling Adding air handler to minisplit: is there an isolation valve?? May 26, 2020
HVAC Heating & Cooling Adding a Manifold Mixing Station Nov 12, 2018
HVAC Heating & Cooling Adding radiant heat to existing hydronic baseboard heating Apr 16, 2018
HVAC Heating & Cooling Adding a C wire to my 2 wire thermotat Mar 20, 2017
