Adding bathroom to detached garage.. Sewer line?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Evader53, Jul 1, 2019.
  1. Evader53
    Evader53 New Member
    Jul 1, 2019
    CA
    Hello, new to the forum and looking for some advice.
    We have a detached garage behind our house with a finished room above. We’re looking to add a bathroom, and the biggest obstacle is going to be sewer connection which is in front of the house. The total line distance will be 100’. I’m in the process of trying to make sure I’ll have enough slope to make the connection. We have a cleanout right by the front patio, and there is a small (roughly 1’ wide) circular concrete cover stamped sewer about 6’ away towards the street (still in our yard). Removing it exposes the top of black capped pipe about 5” in diameter if I remember correctly.
    What is the best way to do this? Do I need to dig around this capped pipe and find how deep the sewer line is, then use a laser level to measure depth? Would the new line be connected between the cleanout and this pipe?
    FYI, I’m not tackling this myself, just trying to make sure it’s feasible before calling in a plumber/GC
    Thanks
  2. OLD TIMER
    OLD TIMER Member
    May 18, 2019
    FLORIDA
    Dig up that clean out by the front patio and see what you got. depending how deep it goes you could tie right into the drop. I hope you have 4" pipe going to the city sewer because when your done i'm guessing you'll have more than two toilets on your property.
  4. 54fighting
    54fighting New Member
    Jul 3, 2019
    Los Angeles CA 90049
    I'm probably not visualizing this correctly, but would an ejection pit be a solution? I have a room above a garage at the back of the property. We installed an ejection pit, and it has worked pretty well over the last two decades.
Similar Threads: Adding bathroom
Plumbing Forum, Professional & DIY Advice Moving Kitchen Sink and Adding Bathroom Nov 23, 2021
Plumbing Forum, Professional & DIY Advice Adding 3rd bathroom sink drain/vent to double sink configuration Aug 24, 2021
Plumbing Forum, Professional & DIY Advice Adding a 2nd floor bathroom - venting and drain questions (see diagram) Apr 12, 2021
Plumbing Forum, Professional & DIY Advice Adding Utility Sink next to Bathroom Mar 19, 2021
Plumbing Forum, Professional & DIY Advice Adding Bathroom Above Crawl Space Jan 28, 2021
