How do I find out what parts of code I am not meeting? I live in MichiganIt seems like you'd be wet venting something in a way that usually isn't code approved. Will it work ok? I'd say yes.
Yes the left is a kitchen sink, the right one is the drain for the laundry sink. No other drains are connected above. The 2" connects down to a horizontal connection to the main drain which also has a vent. Its just a vent connected to a vent stack.Up.codes says Michigan is using the IPC:
https://up.codes/viewer/michigan/mi-plumbing-code-2015
Can you clarify what the horizontal drains on the left and the right are, and whether they are already vented? Because if they aren't, there's some issues with the connection to the 1-1/2" vent. And if they are, then why is the 1-1/2" vent there?
Related, what story is this picture, is there any plumbing directly below or directly above?
Cheers, Wayne
On the left, if the kitchen sink is vented only by that 1-1/2" vent, then the fitting where the it joins the stack is wrong, it needs to be a san-tee. And the horizontal trap arm is limited to 8' for a 2" pipe, with a total drop of not more than 2". I also see the trap arm is increased in size in the middle of the run, not sure if that's kosher.Yes the left is a kitchen sink, the right one is the drain for the laundry sink. No other drains are connected above. Its just a vent connected to a vent stack.
Thanks for answers Wayne!!! The code doesn't make sense to me since all of the Washing Machine Boxes have 1 1/2 connections to them so I would assume you would connect a 1 1/2 " pipe to them?Perhaps most importantly, the IPC requires that the drain for a clothes washer standpipe be increased to 3" when it joins with any other drain. [Seems odd to me.] So that would preclude tying into the 2" drain there, and would suggest sticking with a laundry tub.
https://up.codes/viewer/michigan/mi...4/fixtures-faucets-and-fixture-fittings#406.2
Cheers, Wayne
Should I add Air Admittance Valves to the Kitchen Sink and the Laundry room sinks to fix the venting problems?On the left, if the kitchen sink is vented only by that 1-1/2" vent, then the fitting where the it joins the stack is wrong, it needs to be a san-tee. And the horizontal trap arm is limited to 8' for a 2" pipe, with a total drop of not more than 2". I also see the trap arm is increased in size in the middle of the run, not sure if that's kosher.
On the right, it looks like there's an elbow going through the drywall on the other side. So if the laundry tub is on the other side, and has a p-trap there, then again the 1-1/2" vent is not properly serving that p-trap, because of the vertical jog of the two elbows. That looks like 1-1/2" pipe, so the trap arm is limited to 6' in length, with a maximum 1-1/2" of drop.
Now, if the drains have vents not shown in the picture, then these conditions are not problems.
Cheers, Wayne
https://www.oatey.com/products/oatey-quadtro-14-turn-washing-machine-outlet-box--833792869 saysThanks for answers Wayne!!! The code doesn't make sense to me since all of the Washing Machine Boxes have 1 1/2 connections to them so I would assume you would connect a 1 1/2 " pipe to them?
That is one approach that would solve the existing venting problems. It would also mean that you don't have a wet venting obstacle to adding the laundry standpipe as drawn (it just need to be 2" and the standpipe needs to be taller).Should I add Air Admittance Valves to the Kitchen Sink and the Laundry room sinks to fix the venting problems?
You are correct it is a 2", sorry I am not a plumber.https://www.oatey.com/products/oatey-quadtro-14-turn-washing-machine-outlet-box--833792869 says
Now would you show me one that says its output is pipe 1-1/2 pipe?
- 2" drain opening fits PVC or ABS Sch. 40 DWV pipe
Thanks for your advice, the 2" drain does connect to a 3" drain but it is not accessible. Basement is finished and connection is behind walls and tile.As Wayne asked, what is below this floor? Does the 2" drain below the floor tie to a 3" drain pipe nearby? If it does, bring the new laundry 2" pipe below the floor, cut the 1.5" tub drain and bring that below the floor and tie it to the 3" pipe. You'll be able to tie into the existing vent pipe for the new work. Cap of the 1.5" at the tee.
