Dgold
Avoid DIYer
Hi all,
I’m wanting to add a sink to my laundry room. On the other side of this wall is a vanity, so I have supply, drain, & vent right here - which is convenient.
Can I use a tee or a wye (and which is correct?) at location B to turn out of the wall (eye swinging out to the left - so the water runs to the right, toward the drain) and then trap then sink (thinking in reverse of flow)?
Or, if I were to install a tee/wye at position C, is it okay to install use a fernco in the wall above the fitting to re-attach the vent?
Thanks to all in advance,
David
David
