Adding a shower to a 1907 home in Hoquiam, WA for my brother Clare
My last project was gutting a half bath and turning it into a 3/4 bath with shower for my brother Clare so that he can skip the stairs to the 2nd floor bathroom which is tough to access since the stroke that put him in a wheelchair. The stroke was in November and his daughter has been kind, taking care of him. The plan is to make his home accessible again to him.
The before on the left, the job as in it's current place on the right.
I can't lift the countertop and carry it out, so a sledgehammer to break it and make it easier to carry.
The wall heater is located where the shower needs to go. The electrical box is unmarked, so a non-contact voltage tester lets me know which breaker to flip before removing it.
The floor is out of level, a home built on ancient ocean bed, very little support below.
The pan shimmed to level, then lifted back up to add the piles of mortar, the pan squished down, lathing screws to hold it in place through the pre-drilled holes.
New ABS drains for lav with AAV, shower and toilet relocation.
Copper in the walls, PEX below, and yes some push fittings accessible below. Considering that I had Covid two weeks previous, and my energy levels were down this Winter and Spring already, it was what it was. Even so, Jamie and I did this on a 13 hour day on a Saturday. I had a colonoscopy scheduled for Monday, which is when they found a 5 CM mystery thing they took a biopsy of and now they want to CATscan me.
By Sunday after a 9 hour day, Jamie and I at least had a working bathroom in place. If we had more time to throw at it, we would have replaced the flooring and painted the walls light gray to go with the white cabinets.
Moen Posi-Temp set up for a handheld.
Ready for the Delta 400 wall set.
Jamie setting the cabinet, shimming the legs.
TOTO Drake 2021 CST776CEFG with C2 Washlet.
I took Doug's advice and offset the rail and the water outlet to either side of the valve so that the hose would loop on either side of the valve. Tuttles Revenge is Doug.
