jayjay06
Hello All,
Wondering if I can do what I'm proposing in the schematic (see the items noted as Added). Basically want to tap into a shower drain in the crawl space to add a drain for Water softener. The drain will be outside the wall and I will put an air gap on the connection to the softener drain line.
I don't really have anywhere to drain this outside.
Would doing this cause a siphoned issue on the shower drain? Shower drain is 2" I believe, and goes into the 3" main below.
Should the trap for the softener be in the crawlspace or can iit be outside (it would be about 12-24 inches higher if outside)?
Should the tap be a sanitary Tee or a wye?
Location San Jose CA
Thanks,
Jason
Thanks,
Jason
