Andrew Schrader
Hello everyone,
I'm adding a second toilet to my home (up/ down duplex if that matters). For my side, the upstairs, I currently have 1 bathroom. The current toilet is 1'-2' from the main stack. I want to add a second toilet in my laundry room that adjoins the bathroom. The new toilet closet flange would be ~8' from the main stack.
Per UPC (MT follows UPC) I should add a 1-1/2" vent for 3" drain or I can run a 4" drain without a vent. Per IPC I can run a 3" drain from the W.C. to the main stack without a drain. If I run a 4" (or even a 3") drain will there be any issues with one toilet draining the other bowl? Since the current toilet is so close to the stack I assume it'll work.
I plan to replace some of the current toilet's drain piping and use a combo wye to connect the new toilet & the current toilet. The new toilet is coming from where I was sitting while taking the picture. Since the new toilet is ~30" horizontally over from the stack, would it be better to do 2 rolled 45s with a steeper section in between, or to drop the ~6-12" elevation vertically and keep the rest of the piping at 1/4" per ft slope?
Thanks,
Andrew
Thanks,
Andrew
