000utback
I have 3 main heating zones/pumps in my old house; oil water heater at approx 180F. Let's talk about one zone. 1-1/4 Cu pipe with Monoflo tees. He services 6' baseboard, 4' baseboard, 8' baseboard, cast iron radiator, 7' baseboard. Each of those is on his own tee set, using 3/4 Cu and/or Pex.
The PO left an open set of tees to supply a future room (sunroom). I put an 8' and 10' baseboard in series fed from the one tee set, plus the pex tubing to run 18' from the tees to heaters. - twice as far as the other heaters.
The good news is that the inlet temperature for the sunroom is the same as all the other heaters, indicating that the monoflo tees are still diverting plenty of water, in spite of the greater distance and 2 rads in series. I checked that with an FLIR viewer after starting the furnace on a cold day. All the heaters had very similar heat rise.
Query now, is that the sunroom still doesn't get enough heat. I would like to add another 4' baseboard in series. This doesn't have much impact on total length, since it really means that I'm poking the return line up, through the heater, then back down, so the increase in back pressure is only 4 elbows and a couple feet up/down. My concern is at what point I create too much resistance and get less water off the tee, thus negating what I did by adding another heater.
Cutting in to the main pipe and adding another set of tees, and doing another 3/4 run to the heater, is a lot of work and expense.
Do ya'll think that adding the 4' section will hurt my flow much?
thanks for any advice. I appreciate all that I have learned on this forum.
- White Cloud
- White Cloud
