Chuck Pulsinelli
prop
I'm in Mexico and have a well that is about 22 meters deep. It`s just a 4 inch PVC pipe in the ground and I have a 1 hp pump above ground and get good pressure . I'm trying to pump water up to my storage tank about 10 meters up and about 20 metres away from the pump. the outlet hose is probably 1" id and the hose going up about 3/4 id it will pump up for a few minutes and then stop. the line going into the well is probably an inch and a half hose and I hit water about 5 meters down the hose is about 12 meters long. I tried using a 1/2 " hose going up to increase the pressure but stops pumping after 5 minutes or so and the pressure is minimal. I have another 1 HP pump I could connect at the up point, would that work? I also thought 1/2 inch PVC up might increase the pressure up. Any ideas? Thanks for any help
