Add a bar sink Ontario Canada
Discussion in 'Canadian Plumbing Code Questions' started by 1313, May 20, 2019.
  1. 1313
    1313 New Member
    May 20, 2019
    Ontario
    Is it possible to legally add a drain to this existing configuration 3" stack for basement bar sink, I was thinking of cutting into the line going to kitchen sink bring it down to join into 3" near ground level, and adding a tee from new pipe out to new sink
  2. Sylvan
    Sylvan Still learning
    Sep 23, 2004
    plumbing- - fire suppression
    New York
    How you you plan on venting the new fixture?
    Also if under the slab there is a short radius fitting you can have waste flowing back to the new sink connection
  4. 1313
    1313 New Member
    May 20, 2019
    Ontario
    That is why I thought to cut into kitchen drain, so it would act as a wet vent, it has to have it's own vent as I have seen inside the wall in the laundry before and know there is no ABS going horizontal to kitchen. That being the case it only has 2 FUs and therefore the 1 1/2 pipe can be used as a wet vent if I understand the code correctly. How to cut into is what I am am most troubled by. Horizontal pipe to kitchen is right under joists no space to cut into pipe in that vertical section
Similar Threads: sink Ontario
Canadian Plumbing Code Questions Toilet & Sink rough-in May 4, 2019
Canadian Plumbing Code Questions Island Sink Venting Oct 25, 2018
Canadian Plumbing Code Questions Sink not CSA approved Dec 2, 2017
Canadian Plumbing Code Questions Plumbing washer and sink and standpipe Jul 21, 2017
Canadian Plumbing Code Questions Canadian Plumbing question ( indirect drain & new garage sink) Jul 19, 2017
