Active underground water leak in winter — immediate repair vs waiting?
carlosolson
Technical Background | Plumbing Repair
Obion, TN
carlosolson.com
Weather: Overnight lows approximately 25–32°F
I’m looking for professional judgment on whether my decision-making was sound and what licensed plumbers would have done in this situation.
Timeline:
  • Prior to working on the kitchen sink drain and faucet, I ran all fixtures (faucets, shower, dishwasher, etc.) to flush the drains
  • Shut the water off for approximately 1–2 hours to perform kitchen sink drain and faucet work
  • The following day, noticed continuous flow with all fixtures off (~16 seconds per gallon)
  • Shut off the main and determined the leak was in the underground water distribution line
  • Noticed pooling water in the middle of the yard as well as at the beginning and end of the distribution line
  • With active leakage and freezing temperatures, I excavated a trench to locate the failure
  • Found extensive corrosion in the distribution line, including severe deterioration around threaded joints as well as through-wall holes and cracking in the center sections of the pipe
  • Based on the condition of the pipe along the run, I replaced the entire distribution line rather than a single section
  • Restored service, confirmed no leaks, and backfilled
Additional context:
I’ve attached photos of the failed sections. The corrosion appears uniform along the pipe length, with multiple holes and cracks rather than a single localized rupture.
Repair details (for context):
The original line was 1/2” iron pipe. I replaced it with 1/2” PEP to match the existing service size, as the line feeding into the meter and distribution shutoff is also 1/2” PEP. Approved transition couplers were used with stainless clamps and thread sealant where applicable. The repair was pressure tested with no leaks before backfilling.
Questions:
  1. Is it plausible that briefly shutting off the water could have caused an underground water distribution line to fail?
  2. Could running fixtures to flush drains prior to shutting off the water contribute in any way to an underground line failure?
  3. Based on the corrosion shown in the photos, does this appear to be long-term degradation rather than a sudden failure from normal fixture use?
  4. With an active underground leak and freezing temperatures, would you have excavated immediately or waited?
  5. What risks would there have been in delaying repair under these conditions?
I’m looking for honest professional feedback and what you would have done differently. I appreciate any insight.
Slomoola
Active Member
OKC, OK
Yes. Pipe went from full pressure to zero.
You need 40-60 psi on the house run. Test yours and see what you got for pressure.
sure.
Long term. I would never put iron pipe in the ground. Two words come to mind, rust and his buddy corrosion. Not a recipe for an enduring fix.
That entire line was a time bomb. I hope you protected and insulated the new pipe. Pipe insulation on the service line inside a 2" PVC pipe. Or run two service pipes while you are there. Think about future issues. Make it easy on the next guy. PEX A pipe is cheap.
