Tim Fastle
So, I started this in the water well forum and am now here. Long story short, I need to move my well pressure tank and pressure switch to accommodate a filter, softener and supply after an addition (about 40 feet). At the new location I do not have 24oAC nor incoming wires from the well (those are both at the old tank location).
I hope to move the pressure switch to the new location and actuate the pump via a contactor (or relay) at the old location. I am thinking I would install a 24vdc transformer at the new pressure switch location and run two wires from it (one through 1 pole of the pressure switch as the switch leg) to a double pole NO contactor at the old tank/pressure switch location (about 40 feet). Then wire it up through the contactor with the 240vac supply on one side and the well pump controller on the load side (as it was wired with the pressure switch there).
I don't know a ton about relays and contactors. I gather they are basically the same but contactors are better for heavy load applications. I believe it's a 1.5 hp submersible pump, 24ovac, single phase. It draws just under 10 amps when it fires up and runs at about 9.5 amps per my meter. Does this sound like a reasonable solution to those in the know and how might I search and sourse the transformer and contactor. Or should I just use a relay (as in this is not a load that needs heavy duty)? I was thinking a contactor would be more heavy duty and reliable but I don't really know that. I looked around at some suppliers online and could not make heads or tails out of the specs with regard to their contactors and relays because I am not remotely familiar with the terminology. I am thinking 24vac because it seems to be somewhat standard but am not married to it if there's a better option. Also, what gauge wire would I need for a 40 feet run in this case. I'm guessing not very heavy.
Any thoughts or input would be appreciated.
