Hi,
After replacing some rotten subfloor and new cement board, I was laying out my tile, cut the hole, and dry fitting my flange on top of the tile as I've read is the proper method.
My concern is now that the flange will be sitting higher than it was orignally installed (which was flush on sub-floor below the cement board and tile). The 4" "barrel" I guess as it's called of the Oatey flange won't go as deep or as far over the 3" drain line.
What is the acceptable overlap? Should I try to find one that has a longer barrel? I marked a pencil line and it's just over 1/2" overlap in the attached photo.
Thanks again!
Thanks again!
