VAWellDriller
Active Member
I have a 2 story house on a basement. The whole house has a gravity drain sewage line about 6ft off the basement floor to my septic tank and drain field. I have a basement bathroom and washer that drain into a sump pit, with grinder pump that tees into the main sewage line.
The 2nd floor air handler is located in the attic. The installers ran the condensate drain from attic down to my mechanical room sump pit; so several times a day the pump kicks on just because of the condensate. There is a vent stack in the attic very near the condensate line; is there any code or otherwise reason that I shouldn't tee that into the vent and let it drain by gravity......just to eliminate the extra pumping in the basement?
