ABS hub broke. Need advice.
Antil
Do I have to replace the whole hub or there is another an easy and a reliable solution. Thanks!
sometimes, if you get too generous with the cement inside the hub, it gets pushed to the bottom of the socket and softens the ABS. Then, over time, pressure eventually snaps the weakened connection right at the juncture with the main body of the fitting.
Antil
Thanks for your replies. I am replacing the hub this weekend. I have no idea how this happened. Lived at this place for 5 years and two days ago I had seen the leak in my garage and my basement. I have had my roof repaired recently but I can not see the leak problem related with the roof. Who knows ?
