I am considering the following project:
I have a barn with a finished (rough) 700sq ft room. I am interested in turning this space into a guest suite/man cave. There is no water service at the barn. The barn is 700ft from the road. I was considering using a 5000gal water storage tank that a family member has given me as an above ground well of sorts. So far here is what I have come up with.
5000gal Tank
1/2hp Flotec submersible pump w/ control box
Submersible float switch
40/60 pump switch
32gal Water Worker pressurized well tank...anything else equipment wise (aside from water lines)? I would think I would need a relief valve but I am not certain. Where would I install one if it were needed?
The water tank will provide water to: 1 kitchen sink, 1 bathroom sink, 1 sunmar composting toilet, 1 shower.
Black Water will drain into the composting system. Gray water will drain into small septic system.
Any help is greatly appreciated.
5000gal Tank
40/60 pump switch
