Above floor rough trip lever tub drain
repair
Honolulu, HI
I am installing an above floor rough bathtub with the drain going into the wall. Does anyone sell a trip lever drain where the drain goes back into the wall instead of straight down to the floor?
Thanks.
You are installing with a p-trap, right?
A cable drain like the Gerberit can be installed with the santee pointing down or back. You do need a p-trap in there somewhere though.
repair
Honolulu, HI
I'm replacing a tub in a condo so it should have a p trap. I'm assuming something like this gerber will not work with the tee rotated with the drain pointed back?
