I did this shower a number of years ago, prior to most of the training I've subsequently had, and yes, there are some rookie errors in it, but it works, doesn't leak, pleases my mother which was the major point. She chose the tile and the small room dictated the layout. Had to turn the toilet 90-degrees, which was a pain with 6" CI pipe underneath tight up against the plaster ceiling below. Plank floors got 1/2" ply added and had the window to deal with and wanted the shower as wide as possible in the space while still maintaining enough gap to the sink required by code for passage...it was close. I thought the wall extension was novel, and keeps you from bumping into a square protrusion if you go in there at night without the lights on. The plaster walls are not plumb, so some of the cuts in the corners are weird since they are not flat, either. Messing with them would have made the transition into the room, especially with the window there a big eyesore, so were left. The ledger board slipped and since I did the corner pieces last, I didn't notice until it was too late. So, the niche didn't quite line up as I'd planned. Anyways, it works, and I know better. It does not leak, and has been solid for a number of years. So, yes, I have tiled something, and there are other projects that aren't easy to photograph later that I may get a chance to include as time and the opportunity arises. The seat is by Innovis http://innoviscorp.com/better-bench and, having it floating makes the shower look and feel bigger. And, if you're facing it, you can have your feet underneath, which does give you more room. The ADA rated safety bar is from WingIts www.wingits.com and I used their commercial SS anchors. You need careful measurements (I used a board with a hole bored into it to help hold the diamond core bit from walking) as the slots in the bar's mounting flange only have a very short slot for leeway. Those things are really solid. Expensive, but if you are retrofitting and do not have blocking in place, they provide an ADA rated solution to adding a bar.
