guys - I live in a 2 floor home with crawl space attic with a current oversized furnace & a-coil that I'm upgrading to smaller units and high efficiency. Does it really matter where the exhaust vent & intake PVC ducts go through - side wall which is approximately 10' from side wall or shingles roof? I'm in NYC and not sure how high the wasps can go - I'll be placing some sort of screen but should I also install a back-draft damper in both PVC ducts?
Also, how would you typically run the drain/condensate pipe? Is it to the nearest bathroom drain or should I drain it directly out through a PVC connecting into my gutters?
