96% high efficiency furnace
Dokat
nyc
guys - I live in a 2 floor home with crawl space attic with a current oversized furnace & a-coil that I'm upgrading to smaller units and high efficiency. Does it really matter where the exhaust vent & intake PVC ducts go through - side wall which is approximately 10' from side wall or shingles roof? I'm in NYC and not sure how high the wasps can go - I'll be placing some sort of screen but should I also install a back-draft damper in both PVC ducts?
Also, how would you typically run the drain/condensate pipe? Is it to the nearest bathroom drain or should I drain it directly out through a PVC connecting into my gutters?
Thanks
Fitter30
Peace valley missouri
Intake and exhaust can go either wall or roof but have to check the installation manual to be sure. Can't use a backdraft damper and wasps can go higher than a two stories. Condensate from any burner is corrosive has to be neutralized before going into a drain not a gutter.
Dokat
nyc
So how do I handle wasps? For my basement unit, I change to a very small hole material sold by this company that keep wasps out and change to bigger holes in the winter so there is less restriction
Dokat
nyc
Also side question - I recently installed a 8" fresh air intake and it's in a goose neck configuration. Do goose necks normally prevent insects from going in? The HVAC engineer said no insects will go in and climb up. Is that true?
