DIYorBust
Active Member
Here's what I'm thinking. California faucets makes a 1/2 inch thermostatic valve with a built in 2-way non sharing diverter on top that can pass about 7gpm, and a tub filler on the bottom than can pass about 11gpm. I will have a handshower, a regular shower, and a tub filler in this setup. I would like to be able to run the hand shower and main shower at the same time, but in california, this would be against code, hence the non-sharing diverter. However it does not appear to be a code issue where I am, in NY.
My idea is to run the hand shower to the tub filler valve, and the tub filler to one side of the diverter. Since I can't think of a reason to fill the tub while the main shower is running, I think it could work, but the flow to the tub would be restricted to 7gpm.
Also would be interested to hear about alternative ideas. I have tried to avoid a multi volume control setup because the added cost of additional roughs and trims is expensive.
This is the valve:
https://www.calfaucets.com/bathroom...s-and-integral-single-volume-control-th52d2-r
DIYoB
This is the valve:
DIYoB
