6.5 yr old A O Smith Water heater - never drained. Drain it now?
keg312ua
Atlanta Metro Area
Howdy,
I'm as far from a plumber as one can be. But I've got an AO Smith 50-gallon gas heater (XCG-50 400). Replaced about 6 years ago. House was built in 2008 so that would have been about 11 years on the first heater - a cheap builder grade, but I don't remember the model. It (the old one) sprung a leak from the expansion tank, so I replaced the heater and the cutoff valve. I've never drained the new one. It's working well, and in the Atlanta area we don't have a problem with hard water (family in TX and they have damn near abusive water).
My question is - with no problems at this time, is there any strong reason that I should drain it? Any strong reason against it?
Process looks straightforward enough, I just need to see about how to turn off and back on the pilot light, but that aside, just wondering if it's worth it.
Thanks in advance,
~j~
Yes flush it. You need a full flow 3/4" boiler drain to get all the junk out. The factory drain is too small and doesn't allow all the junk out of the tank. Look for full flow valves. I bought a coupe off the internet. They are a full 3/4" inside.
Remove all anodes. Replace with the electric style.
