TequilaMB
My 507 Basement Sentry system alarm went off today. We'd had a main pump failure yesterday (but caught it early enough that the battery backup unit had not kicked in). The charging light on the 507 was yellow, but the alarm still would not go off hitting the reset button. I discovered that the unit had inadvertently been unplugged from the A/C power overnight. I checked water level, it was low, so I refilled it. Plugged it back in, then it started flashing yellow/green yellow/green, but it would not stop squealing until I unplugged the unit from the A/C power again, and then removed the connection from the negative terminal on the battery. Would this indicate the battery is dead, or just that it needed refilling? Tried calling Zoeller, but they're not open on Saturday. How does one go about "having the battery checked"?
