5 - 10 gal under-sink electric water heater, 240V, not just "hand washing"
Lifespeed
California
I have a slightly unusual water heater requirement, for a "Granny Unit", if you will. It will be a new installation, preferably under-sink as space is limited, with 240V service available at the panel. I am checking on the ampacity now, but with the installation of a ductless mini-split heat pump, it may be that not more than 20A to 30A are available. I will, of course, confirm before proceeding further.
I mention this because a 20A tankless has very limited capacity - 45F temperature rise at 0.5GPM. So probably this is an application for a small 240V tank, not the typical 2-gallon under-sink 120V "hand washing" tank fed from a real hot water heater. This application will be standalone, fed from the cold water supply.
WorthFlorida
Solutions
Orlando, Florida
This company has dozens of different wattages and voltages. If it is for a bathroom sink use only, a 15a 120 volt unit will provide 105 water. Look for the low flow, .2 gallon per minute before it turns on. For higher needs such as for a tub or shower, there are larger (different) units with 240 volt rating
https://www.chronomite.com/instant-flow-tankless-water-heater-sr
Lifespeed
California
Good link, and a USA company. Although that doesn't clearly define country of manufacture. Lots of different power ratings, as you mentioned, so you can fit within available electric service.
It is for a kitchen sink application, so a bit more demanding than bathroom lav. I think if we can supply 20A, or preferable 30A, a Chronomite will be fine.
