45 PVC elbow vent only?
Discussion in 'Illinois Plumbing Code Questions' started by Kevin71246, Mar 21, 2018.
  1. Kevin71246
    Kevin71246 Member
    Mar 13, 2018
    Chicago burbs
    I see tons of questions about a 90 being vent only (short sweep), but can't find anything about a 45.
    Is there a 45 elbow that's for a vent only, and not drain? In the attached screenshot, I'm wondering if the bottom 2 are for vent only? If not, what's the difference between the top 2 and the bottom 2? It seems the bottom 2 has more glueing surface which I prefer but not sure if I can use it. I'm in Chicago burbs btw.
    Thanks all!
  2. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
    Kevin71246 likes this.
  4. Kevin71246
    Kevin71246 Member
    Mar 13, 2018
    Chicago burbs
    Appreciate the response!
  5. hj
    hj Master Plumber
    DWV also means they have "radius" turns. Sch 40 fittings have "sharp" angle turns.
  6. Kevin71246
    Kevin71246 Member
    Mar 13, 2018
    Chicago burbs
    HJ, does your comment mean the bottom 2 "sch 40" fittings, being "sharp" turns, should not be used for drain? If so, what can they be used for? Only supply & vent? Thanks!
  7. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    The bottom fittings are intended for use in supply lines, as in cold water supply from the curb stop or to an outbuilding. They would not nornally be used inside a structure.
  8. hj
    hj Master Plumber
    They could only be used for vents, but normally only in "emergency" situations where a DWV fitting would not fit
Similar Threads: elbow vent
Illinois Plumbing Code Questions Venting 4" floor drain under slab in middle of room.. May 18, 2020
Illinois Plumbing Code Questions Island sink drain and vent (new install) vent question Jan 29, 2020
Illinois Plumbing Code Questions CPVC for venting EXHAUST oh no you didn't! Nov 30, 2019
Illinois Plumbing Code Questions Vent line thru multiple king studs/top plate. Aug 1, 2018
Illinois Plumbing Code Questions Venting Diagram for new basement bath Jul 20, 2017
