$400 vs $900 irrigation pump
55tbirdfan
Clarkston Mi
I am replacing 30 yr old irrigation pump for my sprinkler system. Was a 1½hp Myers pump. Pump still running but think the body has just about rusted thru.
I am looking at pumps in the $400 range and wondering if I should be looking at more expensive pumps but do not know what the advantage is.
Both higher priced and mid range priced seem to have same hp, gpm, cast iron housing and polymer impeller.
Wondering if I will get 2x the life out more expenssive, (allegedly) better made pump.
One thing that can differ is the number of stages. More stages can generate higher pressure.
SuperSurvival
Putnam CT
Probably very little difference. Even the expensive pumps are cheaply built these days. Post some links of the pumps you are looking at.
How about this one;
55tbirdfan
Clarkston Mi
I was looking at 1½ hp centrifugal pumps by Sta rite, Berkeley Myers and Goulds. All of these were $700+ -$1100.
The big box versions are around $400 for Zoeller, Barracuda and Wayne.
All 1½ Hp, 1½ or 2" inlet and 1½ outlet and all are 230Volt.
If I jump up to 2hp pump on a couple the impeller is brass instead of polymer.
Original was a Myers 1½ centrifugal pump, about 70gpm, with 230 volt.
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
Is the pump you are replacing a Jet Pump or a Sprinkler pump?
WorthFlorida
Solutions
Orlando, Florida
His original post stated it is an irrigation pump. 55tbirdfan, stay with a 1.5hp pump. Increasing to 2 hp the well may not be able to provide enough water (slight chance it cannot). You know 1.5 hp works. Nothing wrong with the big box store pumps. Most newer pumps the motors are all the same (made in Mexico) and they burnout or the bearings seize before the pump parts ever wears out. Pretty much what the Valveman stated. I had a Sears irrigation pump (Sta-Rite), bought in 1997 and it still was running when I sold the home in 2016.
