I've got several questions so I'll try to ask things in order. Bought a piece of property near Rockport, TX that has several 4" PVC wells. After the hurricane but before I bought it everything was pulled and jetted. One well is apparently bad (makes less than 5 GPM when jetted, was 40+ originally) so the pump was left out. I have to believe this failure was unrelated to the storm but nonetheless. On the second well the pump was stuck when pulled. Rope, wire and poly drop pipe were broken pulling the pump so I don't know if the rope broke first and stuck the pump or what exactly happened. Either way, it jetted fine and the well driller says we are good to go back with another pump. Picture of the now bad pump that came out of this well is attached.
What is the black plastic thing on the bottom of the motor? Previous owner and the well driller says the well makes some sand so they had a steel settling tank after the pressure tank and drained off the sand periodically. Would this on the motor have something to do with sand/water flow/etc?
So now I have a good pump that came out of the bad (5 GPM) well that I'd like to put into the good well. I know these are not the best brand pumps but I'm trying to get by for now without spending much money. Eventually I'd like to have a proper 20+ GPM well with no sand, but that will have to wait. Both pumps have the same model number so I'm assuming the pump end is the same. They appear to have different motors but both 1/2 HP with nearly identical amp ratings.
Good pump pictures attached.
Forgot to mention wells are about 180', not sure on static level or where the pumps were set. I can measure the broken pipe and wire to get a good idea.
Any reason I can't use this pump in the good "sandy" well? What about reusing the poly pipe and wire? Any other things I need to be cautious or aware of? I've done this before but it's been years and on less than 100' wells.
More questions likely to come but that's enough incoherent thoughts for now. Haven't been on this forum in years and I really miss it.
Thanks,
Travis
Thanks,
Travis
