I know it probably doesn't exist but I've had a piece of 4" pipe that is the inspection pipe for my drain field that has been cracked straight through and I've repaired it before only to have it fail several months later.
The trouble is that to replace the section of pipe will be a nightmare because of the soil etc.
Is there (probably not) SOME sort of flexible? pipe that is used to fit snugly on the INSIDE of a 4" drain pipe?
Something that is meant for a temporary or even permanent? repair? -- thank you
