I realize the: twice the volts = half the amps part. It just seems to me that it would draw more if it was turned up.
Thanks, I was just trying to understand the last part of post #15. Duty cycle with welders usually relates to the percentage of time it can weld before overheating and shutting down.
NO, no, no!IF you were hard wiring it, you would connect the wires to the two hots AND THE NEUTRAL, not the ground. Three wire cords connect the ground and neutral together. IF you rewire it for 4 wires, you disconnect the internal ground from the third (neutral) lug and then connect it to the fourth wire (ground).
Can you tell me where you are getting this???The neutral needs to be on a Current carrying conductor, not the ground wire. That welder uses 120 for the wire feed even tho it runs the Output transformer on 240V for the welding wire.
I see that it can be wired for 120V OR 240V. I see NO WHERE that it states the wire feed runs on 120V.
WHY?? All that matters is the input voltage rating. What they do with that voltage once inside the machine should be none of our concern. UL already worried about that.The Wire Feed Speed Controller, looks like it runs off of a 120V step down isolation transformer. As near as I could tell.
I was looking at the internal wiring schematic.
Again, what AT ALL does this have to do with a residential installation??I think it is like that because Arc Welders make a lot of noise on the AC line.
If they use a separate isolated transformer they have a better chance of filtering the AC noise and RFI that the arc produces.
That is just my guess. But would be a good design practice.
It is important for the Wire Feeder to run at a constant and smooth rate, or your weld can suck, and is not smooth like it should be.
Have Fun.
Does it call for a 240V feed? Then feed it with 240V. Same for 120V.
I'm not sure why this is even being questioned.
Hmmm...the specs say differently. Do you know something the manufacturer does not?I just was stating what I found.
That welder will not work on a normal residential 120V outlet, You should know better. It does good to work on a residential 240 V outlet, and that is required to make good welds.
Funny, I own a stick welder as well as a Millermatic 175. What does that have to do with it???My guess is that you have never used a wire feed welder.
I Did. I shows both 120V input or 230V input. Do you not see that?Please check the schematic for yourself, and correct me if I am wrong.
I'll help you along. See the top of page 2: http://www.millerwelds.com/pdf/spec_sheets/DC12-54.pdf
