TSPORT
Hi all. This is an HVAC electrical question. I'm dual-posting in the HVAC section to solicit input from the HVAC pros as well.
We had our complete HVAC system replaced last year. Twice in the past month the 30 amp breaker for the A/C compressor has tripped.
Never happened before with current system or prior system. The house was built in 1997 and the breakers are original. The breaker is on a dedicated circuit for the outside compressor unit. I called the HVAC company. They came out and checked things over. The tech seemed knowledgeable. He said everything looks OK with the HVAC system but that the compressor is rated for a 35 amps. He said the 30 amp breaker is old and recommended I replace the breaker with a 35 amp breaker and said the wiring is 10 awg and it's fine.
Is it safe to replace the 30 amp breaker w/ a 35 amp breaker in this situation?
If not, is it possible the 30 amp breaker is "wearing out" causing it to trip prematurely and should be replaced?
