NTL1991
Trying to get to the bottom of a drain issue and hopefully sort things out. First floor toilet bubbles (enough to wet the bottom of the toilet seat lid) when the third floor toilet is flushed. Flushing the 2nd floor toilet only causes some minor disturbance in the 1st floor bowl, similar to that of a windy day. Same deal at the 2nd floor toilet when the 3rd is flushed, no bubbling.
The soil stack is 4" cast iron and vented through the roof. All late 40's cast iron except for the basement portion of the stack which is horribly noisy PVC. House drain is 4" PVC as well.
1st floor toilet 4" closet bend -> 4" reducing wye (lav & tub used to tie in here) -> 4" combination w/ vent line up adjacent to soil stack -> 4" soil stack to house drain
I'm assuming that the second floor also has a similar vented combo, with it's own vent line, and they all combine above the 3rd floor level before the stack is vented through the roof. Does that sound right?
So I'm thinking that the falling water from the 3rd floor is pushing quite a bit of air ahead, and the air is finding the easiest path to be through the water in the 1st floor bowl, right?
That would seem to mean I have a blockage I need to investigate in the soil stack below the 1st floor combo, the house drain or the 1st floor vent line, right?
