Jebusfreek666
I am in the process of renovating and updating my entire house. Currently, I am looking into redoing the entire water supply runs as there are no outside water bibs, and I am adding a bathroom and moving around the kitchen. Due to these changes, I would like to switch to a manifold system. The issue I am researching now is the subject of this post. My house is about 120 years old. The supply line in the basement from the city appears to be 3/8". The best manifolds that I see that have the number of outlets I need, plus a couple for expansion if needed, are all 1/2 inch in/out. Can I use these manifolds? I realize I can use an adapter to make the inlet on the cold side 3/8", but doesn't that completely negate the benefits of using the 1/2" outlets and PEX? I also realize I can still do 1/2" from the water heater to the manifold. But that water heater will still be fed originally from the 3/8" cold supply line.
Basically, am I okay with this setup or should I be looking into getting 1/2" supply line to the house? It will be a 2 bath when I am done, one with both tub and multi-head shower.
