3.5 bad addition on a well with pressure
Kennedi
Michigan
Addition of a master bath, one full bath and one half bath the washer room over a crawlspace and to connect to existing septic and leach feild. We'll water, not municipal. My question is should what should I use for h20 supply lines to my fixtures since we have a high fixture count.
3/4 inch PEX to the cold for a full bath. 1/2 inch PEX OK for the hots and the cold for 1/2 bath. Insulate hot. 1/2 should be OK for the laundry where it is not carrying other water.
If you will run hot recirculation, that changes the plan. I am not a pro.
Read up on well sanitizing. https://terrylove.com/forums/index....izing-extra-attention-to-4-inch-casing.65845/ is my write-up, which may be overkill. Get your septic pumped often enough. Often enough could be every year, and it could be 7 years. Get advice from the experienced person doing the pumping.
