Brad Littlejohn
I am replacing p0ly B with PEX. Starting to replace my line between the meter and the house first. I found out that the main line is 3/4" ish almost 1". It is old black plastic pipe. It uses barb fittings. There is a hugh difference in diameter from the old 3/4" to the new PEX 3/4". With that said, would it be correct to upgrade the main line from the house to the water meter to 1" PEX to maintain the same static pressure? The water meter is 3/4" will a larger pipe through off a meter reading?
Thanks,
Brad
Thanks,
Brad
