20A vs 15A GFCI for Bathroom?
Idoc4u
Indiana
Do most recommend a 20A GFCI outlet in a bathroom as a result of the potential wattage used by hair dryers and other small electrical appliances that use a great deal of watts?
Thank you.
Jim Port
Electrical Contractor
Maryland
www.manta.com
There is no need for a 20 amp slot GFI in a bathroom. You will not find appliances in a residential setting that need the T-slot. Even a 15 amp slot GFI is rated for 20 amp thru-put.
Alectrician
DIY Senior Member
20 amp circuit (#12 wire), yes.
20 amp receptacle (the thing you plug the hair dryer into), no.
