200 ft deep well with a 2" inlet pipe. what can i do to get water
pingert
sundridge, ontario canada
Just moved northern ontario. I have a well 200ft to the bottom , I get water at 70 ft. down from the surface, Having a problem finding a solution that works in a 2'' pipe. love some help.
THANKS UP FRONT
rod
With a 2 inch pipe, you will need a "single pipe" jet pump system with the jet/ejector (venturi+nozzle) down the well. One key word to look for in your searches is "leathers" and "injector"
index.php
You will need to think about freezing. There are pitless adapters that can be used, or you can put the top of the well into a heated wellhouse.
