Hello, folks.
I've learned a lot referencing this forum through the years (as well as johnbridge.com for tiling expertise) and appreciate the time you experts give for DIYers like myself. I finally encountered a problem that I couldn't find in the archives, so I registered and here I am.
I am renovating an older (c 1951) bathroom and going from tub to a curbless standing shower with a single shower head/handheld. The tub had 1.5" drain pipe (with a 1.25" p-trap... one of many things I've had to correct from the previous owner's sins). I've pulled the tub and restructured the floor to accommodate the curbless pitch. I know that 2" drain pipe is generally recommended (and often required) for showers. I live in Michigan, which according to my research has adopted the IPC. My reading of the IPC suggests that a shower requires a minimum 1.5" drain pipe. I planned to go 2" anyway, especially with my vent stack only about 3 feet from the drain and fairly easy to access.
The question is this: would there be benefit in going 2" p-trap/drain line to a cast iron stub that is smaller anyway? Hopefully the attached pic can give an idea of sizing. The current line is the previous owner's handiwork and is 1.5".
I'd appreciate the guidance.
zayd
zayd
