slowgsr
Hi. Can I use my 2 line jet pump to fill an atmospheric storage tank? 500gal.
I'm unsure if this type of pump can operate without backpressure. I suppose once the pressure tank has water in it, that force would provide some back pressure.
I have a low yield well, and I'd like to fill a storage tank at off peak hydro times, running for maybe a few minutes per hour using a timer setup.
The wiring, float system etc I can figure out easily (I'm an electrician). I've hooked up sewage grinder pumps controls, floats etc in the past. I'm just unsure about the specific pump qualities of a 2 line jet pump.
It's a 3' dia 110ft dig well lined with precast.
