Greenmonster123
Active Member
I am designing an irrigation system that will be fed by two wells into the same main line. I want to install a CSV on each well set at staggered pressures with staggered pressure switches. I have done this in the past with wells that were close together and entered the main at the same place with good results. This system will have 400’ between them, is there anything to consider differently with this setup?
