4uzindian
my unit has always run at 142 degrees.st-5 is rated at 150 max psi. the temp is rated at 200 degrees. the # 30 tank is rated at 100 psi. the temp is at 240 degrees. there is no way this unit is going above 142 cause of the aqustat setting.im not worried about that. what are you trying to tell me. I noted before this the same size tank as the origanal.no problems for 25 years. there's no way this is going above 200 degrees. I'm at the end of page 2 are you going to answer me. page 2 or page 3 ?.to all of you. tech came over seen it was wrong expansion tank be here tomorrow to put in #15 amtrol tank .will post to let you all know.
